Help - Search - Members - Calendar
Full Version: Bathurst 12 Hour
Ford XR6 Turbo.com > General Forums > MotorSport
xr6 typhoon
Just a link to the live results page
http://www.bimf.com.au/live_results.asp
thebrunks
It's gonna be a Subi or the Bimmer!!!!
The Bimmer is on a charge after Paul Morris had a huge 67 Lap stint!
xrdreaming
Not many Crappydoores at the pointy end this year. See what happens when they have to race a car thay actually exists and isn't purpose built for the race.
Dagabond
tab
xr6 typhoon
I wonder what happened to the T it only lasted 79 laps
mbjunior99
The first turbo is in 16th with the first Ford being an XR8 in 11th blink.gif
Dagabond
QUOTE
12 Micael Trimble, David Ryan, Andre Fawcett Robinson Racing Developments Ford FPV F6 Typhoon A 141 07:07:52.5815 2:39.8862 19
Me thinks there's something wrong with there system.....
Laner
blink.gif is it just me or was lap 19 when they did their fastest lap??
thebrunks
The Bimmer is in the lead & should finish the job off!
EZ2CME
QUOTE(Laner @ Apr 8 2007, 01:33 PM) [snapback]518924[/snapback]
Thats how I read it to
velociTy
roflmbo.gif roflmbo.gif roflmbo.gif 1st crummydore is in 22nd roflmbo.gif roflmbo.gif roflmbo.gif
mbjunior99
QUOTE(velociTy @ Apr 8 2007, 03:35 PM) [snapback]518946[/snapback]
Laner
we cant get too cocky....car 99 (BF xr6T) is currently 6 laps behind a mini cooper s..... blink.gif
tquarrell
Is car 99 even a T? It's fastest lap is 6 seconds slower than the xr8's fastest and almost 7 seconds slower than the typhoon. Also 4 seconds slower than vxr. That and it's lap speed is similiar to the celica and mini. The other T's aren't much better. Something doesn't seem right...
Laner
if ya look at it, the typhoon is only faster than the xr8 by less than a second on fastest lap time....and the astra vxr is 4 seconds faster than the T.
either way, its gunna be tough for a FORD to get anywhere near a podium, as long as they last longer than the SS i spose!!
DaveO
HAHA Score 1 for the Boss V8!! tease.gif bb.gif stirthepot.gif Got one up on the Typhoon and did 4 more laps. They finished in positions 9 and 10 respectively. Was there watching the 8 hunt down the phoon. V8 sounded awesome down through the twisties!! So much for the Tseries and a Turbo with a DNF. Other Turbos finished 14th and 18th. The 335i's were awesomely fast especially the lead one with the black powdercoat wheels. spoton.gif
tquarrell
so why was the T's lap speed so slow? Have they had a weight penalty or some other penalty? The T should be able to do a lap at least within a second of the xr8. the ss in the tale end even did a lap 5 seconds faster than the T's best. Can anyone explain this?
thebrunks
Because they have a boost limit imposed & the V8 produces more HP.
The T/F6 have the most benefit from 2000RPM, but when racing you are mainly on the higher end of the rev range where the turbo has less advantage.
The V8 would be within it's power range around that track.
Russ
tquarrell
Fair enough, but every test in motor I've seen the xr6 has been pretty close to the xr8 in lap speed around a circuit, as fast or faster. And why was the typhoon able to lap quicker than the xr8 (it has only got 10kw more stock after all)? Still doesn't seem right to me. Maybe they couldn't alter the speed limiter in the xr6t or something (I guess they're still limited to 230km/h stock)? Be interested to know if there is another reason other than the engines power delivery. I guess I expected the T's to beat a 1.8l na celica by a bit more on what is renowned to be a hp track. Maybe they're just average drivers?
thebrunks
Firstly they don't test around Bathurst in Motor. Bathurst has some nice long straights & a very steep hill climb & descent.
As I said before the T is limited by the production class boost level. The F6 comes under performance class & is allowed more boost & is allowed the top of the range FPV Brembos.
Basically the XR's are classed as production cars, the FPV's are classed as performance.
The F6 is allowed to run higher boost & better brakes. After all what manufacturer would like their "production class" car beating their double the price "performance class" car!
There were only 4 a Class Performance class cars racing, 2 x 335 BMW's, 1 Typhoon & 1 T50 Falcon.
Russ
aiboart
Were all the turbo's BF? Any BA's?
What brakes are the XRT's and the XR8 allowed to run, standard BF, or BA premiums or something else?
Regards,
aa
mbjunior99
That would explain the lap time difference between the XR6 Turbo and the XR8 / Typhoon, but how is it that a BMW 130i beat them?? Aren't they a slow car?
thebrunks
The 130I produces 195kw & weighs in at 1375kg, as against 260kw & 1800kg. I'm not exactly sure what minimum weight they run in production class, but it would be based of the showroom specs.
the 130I will be lighter on fuel usage & brakes & with the German Engineering pushing the wheelbase to the max it will out handle a falcon.
The Falcon will have a slight advantage down the straights, but the BMW 130I will absolutely kill it through the corners.
Russ
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
