djkice Boost Addict Member 1,273 Member For: 15y 8m 7d Gender: Male Location: Perth, W.A. Posted 28/02/09 05:19 AM Share Posted 28/02/09 05:19 AM Another FG in here.Ill post dyno sheet once I scan it.Unfortunatly turbo and CAI are nearly at peak. Next is CAI, Intercooler, Turbo upgrade.No doubt it still is very nice to drive at the moment, sounds tough as with the exhaust also. Link to comment Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 15y 8m 7d Gender: Male Location: Perth, W.A. Posted 28/02/09 09:53 AM Author Share Posted 28/02/09 09:53 AM Just made it in here.Was expecting a bit more but ran into some Turbo/CAI restrictions which are soon to be corrected and also the addition of Inter cooler + piping and aiming for the 350rwkw mark.Let's just say the new turbo is great if your happy with the power it comes out with from the factory, it does give you that slight quicker spool. It was also fine running just a tune on it.Having driven a mates car making similar power, I can say my car makes quite good power down low and quickly but lacks top end. Also having been in XF Falcon's car, that the approximate power level where I want to be at. Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 20y 7m 23d Gender: Male Location: Newcastle Posted 03/03/09 04:14 AM Share Posted 03/03/09 04:14 AM Great results Djkice, good to see you squeezing some more power out of your FG.Benny Link to comment Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 15y 8m 7d Gender: Male Location: Perth, W.A. Posted 03/03/09 04:39 AM Author Share Posted 03/03/09 04:39 AM (edited) Turbo wise im going the T04Z 66mm Compressor wheel, upgraded bearing assembly, upgraded .7 compressor cover, upgraded actuator and larger wastegateSuprised you have more torque on a factory exhaust but is probably because you have the CAI.I think I need to do more investigatign about the turbos before deciding on what mods to get done to it.... Have you had any recommendations Benny? Edited 03/03/09 04:42 AM by djkice Link to comment Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 15y 10m 6d Gender: Male Location: sunshine coast Posted 03/03/09 05:27 AM Share Posted 03/03/09 05:27 AM why do you need to upgrade the turbo Link to comment Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 17y 10m 25d Gender: Male Posted 03/03/09 05:32 AM Share Posted 03/03/09 05:32 AM (edited) You should make nearly 400 rwkw before you need to up grade the turbo. Edited 03/03/09 05:32 AM by YPURV4 Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 1m 21d Gender: Male Location: SW Sydney Posted 03/03/09 05:41 AM Share Posted 03/03/09 05:41 AM The FG XR has a smaller turbo, most beleive it will max out around 325-350rwkw. Once the cooler and CAI goes on the power should be able to climb a bit higher in the top end... Link to comment Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 15y 10m 6d Gender: Male Location: sunshine coast Posted 03/03/09 05:47 AM Share Posted 03/03/09 05:47 AM wow that's no good Link to comment Share on other sites More sharing options...
RIXT Member 193 Member For: 15y 2m 3d Gender: Male Location: perth hills Posted 03/03/09 06:41 AM Share Posted 03/03/09 06:41 AM hey good to see some numbers coming for the fg mine is booked in for next friday lots getting done including cooler and intake I also want to look at the turbo upgrade seen 400 + rwkw with upgrade you mentioned.Ric. Link to comment Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 15y 8m 7d Gender: Male Location: Perth, W.A. Posted 03/03/09 07:46 AM Author Share Posted 03/03/09 07:46 AM (edited) that 400+ is a built engine mate, with turbo I should reach goal of 350... might hit 375 if luckyTurbo needs upgrade because the compressor wheel is different to FG F6 and BA/BF T's. It is confirmed that the turbo runs out at 310-330 and running it at that level of power it is very inefficiant and cuts top end.good luck with yours RXIT, I put a deposit on a cooler too so hopefully I will get rest of mine done soon after yours Edited 03/03/09 07:50 AM by djkice Link to comment Share on other sites More sharing options...
