cuzzy New Member 12 Member For: 9y 9m 24d Gender: Male Location: Melbourne Posted 15/12/15 07:53 AM Share Posted 15/12/15 07:53 AM My Fg September 2010 build has crap a/c also. Climate control set to cold vent temp struggles to get to 7.0 degrees while at h/way speeds and goes up to 8-9 at idle at the lights. Very average at best, have played around with gas amounts to get compressor to stay on for longer than 10-15 seconds but still no luck. I put it down to poor design. Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 24d Gender: Male Location: Western Sydney Posted 15/12/15 10:25 AM Share Posted 15/12/15 10:25 AM Never been the best in my turbo ute. The fg work ute had condenser leak so I charged it a bit more than ford spec. Works very well now, putting it down to ford running the minimum required charge to save a few $$$. Link to comment Share on other sites More sharing options...
norrs Donating Members 448 Member For: 16y 9m 3d Gender: Male Location: Darwin Posted 27/12/15 09:17 AM Share Posted 27/12/15 09:17 AM Ok so an update. I scored myself a snap-on solus ultra diagnostic thing I got I guy I know who does Aircon to come and have a look. What we found from the scan was that the post evaporator sensor was detecting -13 and turning the compressor off. Even with engine turned off and fans still running it was at -2 even though the air blowing over it was like 30 deg My mate reckons it's the HIM unit that probably needs replacing as he thinks that the stuffed sensor is part of the whole unit. He isn't sure. God dam ford dealership. As you can see from my posts above they could not work out the problem following three visits to them for it and 30 mins with my mate and this diagnostic tool we worked it out. Surely fords own diagnostic machine is better than the generic snap-on one. Any way so what's the go, is the post evap sensor part of the HIMM and I have to replace the whole thing. Can I do it myself or does it need to be programmed to my ecu thing by ford. Link to comment Share on other sites More sharing options...
norrs Donating Members 448 Member For: 16y 9m 3d Gender: Male Location: Darwin Posted 27/12/15 01:23 PM Share Posted 27/12/15 01:23 PM Actually maybe it is separate to the HIM module. Is this it guys. http://pages.ebay.com/link/?nav=item.view&id=291228514143&alt=web Link to comment Share on other sites More sharing options...
norrs Donating Members 448 Member For: 16y 9m 3d Gender: Male Location: Darwin Posted 01/01/16 02:39 AM Share Posted 01/01/16 02:39 AM Ok so I got the part and fitted it and the aircon is now fixed!!!!! After two years I finally have aircon again and no thanks to ford.So for me, the intermittent aircon issue was the post Evap sensor It's was just this $30 part One tip for the fg you don't need to take out the ICC just take out the glove box and the bit on the side of the centre console. Learned this the hardway. 11 Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 4m 7d Gender: Male Location: North West Hot Hell,VIC Posted 01/01/16 04:24 AM Share Posted 01/01/16 04:24 AM Thanks for posting up the part and the fix norrs. There will be a lot of guys with fg models that will be happy with this info. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m 1d Gender: Male Location: Probably above atmospheric pressure Posted 03/01/16 03:01 PM Share Posted 03/01/16 03:01 PM In case the image gets lost in a server upgrade (like I've seen before) the Part No is BG19T563A with description "SENSOR ASSY EVAPORATOR' 2 Link to comment Share on other sites More sharing options...
cuzzy New Member 12 Member For: 9y 9m 24d Gender: Male Location: Melbourne Posted 05/01/16 03:19 AM Share Posted 05/01/16 03:19 AM Great result norrs.I might have to purchase one and see if it helps my fg out. Is it just fit and connect and the a/c works as designed?? Link to comment Share on other sites More sharing options...
bloodycrashboy Feeling the Love :-) Bronze Donating Members 4,409 Member For: 11y 25d Gender: Male Location: Cairns Posted 05/01/16 08:54 PM Share Posted 05/01/16 08:54 PM (edited) Ok so I got the part and fitted it and the aircon is now fixed!!!!! After two years I finally have aircon again and no thanks to ford.So for me, the intermittent aircon issue was the post Evap sensorIt's was just this $30 partImageUploadedByTapatalk1451615537.156336.jpgOne tip for the fg you don't need to take out the ICC just take out the glove box and the bit on the side of the center console. Learned this the hardway. I'm sure that you will be happy now there is aircon. I lived in Darwin many years ago and cant imagine not having aircon in my car!!!!!Disappointing that the Ford dealer is so crap.I've read many so many bad reports of dodgy Ford dealers on this forum, so much so that I do all my own servicing.I also had an issue with my aircon not turning the compressor on, battery was flogged, bought new battery, aircon fixed.Thanks for posting the fix. Edited 05/01/16 08:58 PM by bloodycrashboy Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 11y 18d Gender: Male Location: A big bridge over a river in South Australia Posted 05/01/16 09:43 PM Share Posted 05/01/16 09:43 PM I fitted a new yellow top battery a while back and that didn't fix my prob with the compressor not turning on every now and then Link to comment Share on other sites More sharing options...
