Erko Donating Members 1,079 Member For: 20y 6m 23d Gender: Male Location: Sydney Posted 26/07/09 12:02 AM Share Posted 26/07/09 12:02 AM Your Name: ErkoCar Make and Model: BF2 FPV F6Circuit Name: Wakefield ParkLap time: 1.11.83 Circuitclub.com.au Natsoft timing 25/7/09Modifications: Injectors,pump,surge, IC, Ferodo DS2500 Power: 300rwkwSuspension: Tein SS Performance spec, 27mm front sway, Superpro lower control arm bush (front)Tyres: Kumho KU36 - 38psi cold (note this is far too high - 30-32psi cold would be a good start)Brakes: Ferodo DS2500, DBA5000 front. Stock rear rotor, Racebrakes rear pad, Motul RBF600 fluidBody weight: 1785I hope to get into the 1.09s within a year or so......eventually into the 1.08s. Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 16y 3m 7d Gender: Male Posted 26/07/09 03:55 AM Share Posted 26/07/09 03:55 AM is it possible that these sedans when launched hard, can twist ? like would a 10 sec launch put anythin out ? I heard stories but am not sure. Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 15y 9m 4d Gender: Male Location: Melbourne Posted 26/07/09 07:27 AM Share Posted 26/07/09 07:27 AM Your Name: Joel JenkinsCar Make and Model: Ford Falcon BA MK II XR6 TurboCircuit Name: SandownLap time: 1:30.5200Modifications: 27mm Front SwaybarEngine: StockPower: 198.9 RWKWSuspension: Stock apart from swaybarTyres: Michelin Porsche Cup SlicksBrakes: Standard calipers, 298mm front RDA slotted rotor, QFM K750 pads, stock rotor and pads rearBody weight: Stockhttp://www.natsoft.com.au/cgi-bin/results..../2009.SAND.Q1.I Link to comment Share on other sites More sharing options...
Sprjenkins Member 52 Member For: 15y 9m 4d Gender: Male Location: Melbourne Posted 23/08/09 09:54 AM Share Posted 23/08/09 09:54 AM Your Name: Joel JenkinsCar Make and Model: Ford Falcon BA MK II XR6 TurboCircuit Name: WintonLap time: 1:44.76Modifications: 27mm Front SwaybarEngine: StockPower: 198.9 RWKWSuspension: Stock apart from swaybarTyres: Michelin Porsche Cup SlicksBrakes: Standard calipers, 298mm front RDA slotted rotor, Bendix road pads, stock rotor and pads rearBody weight: Stock Link to comment Share on other sites More sharing options...
MYF6 Donating Members 172 Member For: 19y 4m 15d Gender: Male Location: Earth, I think? Posted 31/08/09 09:10 AM Share Posted 31/08/09 09:10 AM Your Name: CraigCar Make and Model: 2004 BA F6Circuit Name: Lakeside (QLD)Lap time: 1m 10.22sModifications: Engine: Injectors, dump pipe, editPower: 280rwkwSuspension: Whitline front swaybarTyres: Falken 452Brakes: Brembo 4pot front & rearBody weight: 82Kg for meWay too much push from front bar overpowering std rear bar. Tyres not flash for track work! Link to comment Share on other sites More sharing options...
yellowtyphoon Donating Members 31 Member For: 15y 9m 12d Gender: Male Location: sunshine coast Posted 03/09/09 11:51 AM Share Posted 03/09/09 11:51 AM Name Yellow Thyphoon Car make and Model 2005 F6 Curcuit name Lakeside Lap Time 1.07.12 Modifications Atomic Motor , Nispro Intercooler and intake manifold , Exhaust , Tein suspension , PBR M series 6 and 4 pot 355 mill brakes Power 357 RWKW ( lowboost 98 ) Body weight standard Melted clutch line after 48 laps , 4 times 2 times( 2 drivers )6 laps. More heat sheilding required. First time out and hooked . Try more boost next and drop the suspention and wind the shockies up tighter. Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 15y 10m Gender: Male Location: Sydney Posted 20/09/09 09:34 AM Share Posted 20/09/09 09:34 AM Your Name: Paul NobleCar Make and Model: FGXR6TCircuit Name: MarulanLap time: 46.90Modifications: King Springs.Engine: XR8 intake, K&N filterPower: 270kW at flywheel est.Suspension: King springs, stock shocks.Tyres: (Well used) Kumho KU36 front, Falken Azenis RT215 rearBrakes: Front 4pot Brembos.Body weight:77kg (79.25kg after a 6pack of beer) Link to comment Share on other sites More sharing options...
yellowtyphoon Donating Members 31 Member For: 15y 9m 12d Gender: Male Location: sunshine coast Posted 29/09/09 01:30 PM Share Posted 29/09/09 01:30 PM Your Name: Yellow thyphoonCar Make and Model: Ba m2 F6Circuit Name: LakesideLap time: 1:05.47 27th sept 09Modifications: 2Tein suspensionEngine: Atomic Power: 419 RWK high boost 98Suspension: TeinTyres: Falken semislickBrakes: PBR M series 6 and 4 pot with 3555 disksBody weight: 1805 KGNew swaybars and electronic shockie adjustment coming Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 1m 1d Gender: Male Location: nsw Posted 29/09/09 03:15 PM Share Posted 29/09/09 03:15 PM Your Name: Jeremy SmithCar Make and Model: Fiat 124BC sports coupe (U2L sports sedan)Circuit Name: Wakefield ParkLap time: 1:06.57Modifications Engine: Fiat 16 valve, 2 litre, naturally aspirated.Power: 275BHPSuspension: totally custom, full rose-jointed, fabricated control arms f+r, adjustable coil overs etc etc. was a spool diff, now a ZF ramp load clutch pack diff.Tyres: were 15x8 slicks, now 16x10 slicks.Brakes: 4 spot calipers running on approx 290mm vented discs all round, dual master cylinders with brake bias adjustment barBody weight: Approx 850kg with full tank fuel and driver.natsoft timing- http://www.natsoft.com.au/cgi-bin/results..../2009.WAKE.S5.Y.geez mate that's a good time for wfp most of us see around 1.14 or so. Link to comment Share on other sites More sharing options...
jsmith Donating Members 712 Member For: 16y 6m 1d Gender: Male Location: Blacktown Posted 29/09/09 11:33 PM Share Posted 29/09/09 11:33 PM Yeah but it is a U2l sports sedan with full slicks and about 800kgs, not a barge arse heavy XRSince that day we have fitted the new diff which makes the car unbelievably more stable, 16x10" slicks and the next step is a new motor (5cyl ) that we have hopes of making in excess of 300Bhp with (while revving to approx 11000rpm )Haven't run new slicks since mods so with newies hoping for a low 1:05, maybe even a high 1:04. Link to comment Share on other sites More sharing options...
